Pump lower threshold (Water Overlay)
Revision as of 13:42, 15 July 2026 by Frank@tygron.nl (talk | contribs)
This attribute can be defined as values over time, using an array of values defining start-time. This allows users to more dynamically define the target water level this pump maintains.
  • When the PUMP_Q of the pump is positive, the pump will not pump if the water level is lower than or equal to the lower threshold. If the PUMP_Q is negative, the pump will not pump if the water level is higher than or equal to the lower threshold.
  • When using a dynamic LOWER_THRESHOLD, a maximum of 10.000 values (5.000 pairs) can be defined.
Troubleshooting
API Endpoints
