Weir height (Water Overlay)
Revision as of 12:23, 13 July 2026 by Frank@tygron.nl (talk | contribs)
This attribute can be defined as values over time, using an array of values defining start-time. This allows users to more dynamically define the height used to allow or deny water flowing across.
  • When using a dynamic WEIR_HEIGHT, a maximum of 10.000 values (5.000 pairs) can be defined.
  • When using a target upstream water level, the weir height can adjust automatically during simulation. This behavior can also be configured in combination with a dynamic weir height, but can lead to unexpected behavior. Instead for weirs with a target water level, define the weir height as a single start value.
API Endpoints
