Inlet lower threshold (Water Overlay)
Revision as of 12:22, 13 July 2026 by Frank@tygron.nl (talk | contribs)
This attribute can be defined as values over time, using an array of values defining start-time. This allows users to more dynamically define the target water level this Inlet maintains.
  • The INLET_Q should be 0 or positive. Otherwise, the Inlet is not configured to let water flow in.
  • When using a dynamic LOWER_THRESHOLD, a maximum of 10.000 values (5.000 pairs) can be defined.
API Endpoints
