Measure
Revision as of 07:56, 9 July 2026 by Maxim@tygron.com (talk | contribs)
Measures in relation to other Actions.
A measure can be used to:
These actions are configured as spatial components of the measure, spatials in short. There are restrictions on which of these spatials may overlap, in order to keep the measure consistent. For example, two Buildings that are on the same layer cannot overlap. However, other spatial combinations are allowed to overlap. For example, Buildings can be placed on top of GeoTIFF and Terrain spatials.
A measure can be owned by a specific Stakeholder. You can change its name, description, image, cost and construction details. However, a measure can also be performed by other stakeholders, which may override the Stakeholder originally specified.
A measure is an action, which means it can be added to an Action Menu. Also, measures can be activated indirectly using events. Thirdly, they can be activated directly in the editor by clicking on the Activate Measure link:
Editor → Future Design (Ribbon tab) → Measures (Ribbon bar) → Measure → General
When to use measures
A measure can be used to offer predefined plans to stakeholders. Plans applicable to the project can be implemented as measures, incorporating spatial components, costs, and subsequent consequences.
A measure does not need to have a spatial components. Instead, it can also be used to represent a policy change or campaign, which may have consequences for indicators, or may trigger events.
Advanced usage of measures
Because measures can have a large variety of effects and can be activated via events, they allow for the creation of complex project behaviors. Correctly using measures can allow an editing user to create very intricate or specific effects in a project. This does tend to make a project more complex, but can have benefits for the maintainability of a project.
Not showing spatial effects
Normally, when a user selects a measure in their action menu, the spatial effects of that measure are shown. This means locations on the map where the measure has its effect are highlighted, and the user's camera is moved to that location. However, this may not always be necessary or desirable. To prevent this, it is possible to implement the measure as two measures. The first measure contains the cost and description visible to the stakeholder in the Action Menu. A second measure is not directly visible to the stakeholder, but has the actual spatial effect. The first measure can then, upon activation, trigger the activation of the second measure.
Reusing measures
Using the above principle, it is also possible to reuse measures. If multiple measures would have the same spatial effect, it is possible to have an additional measure in which the actual spatial effect is defined. All measures which should have that spatial effect can trigger the additional measure. This has the benefit of being easier to maintain if the spatial effect needs to change. Any change to the plan would only require a change to a single measure, instead of all measures which have the same effect.
