How to add a Levee Spatial to a Measure
How to implement levees as predefined Measure:
- Select Stakeholders → Measures → Add Spatial Measure
- Open the Measure Spatials entry
- Select the WATER 1 (default) entry
- On the right panel, select LEVEE as type from the drop down menu
- Set relative and absolute height on the right panel
- Use brush panel to draw Outer Area, and apply
- Use brush panel to draw Inner Area, and apply
- Select Stakeholders → Actions
- Add new action (if desired)
- Select Assigned Actions
- Add new Measure to Assigned Actions on the right panel
1. Select Add Spatial Measure
2. Open the Measure Spatials entry
3. Highlight the WATER 1 (default) entry
4. Select LEVEE from the drop down menu
5. Set relative and absolute height
6. Draw Outer Area
7. Draw Inner Area
8. Select Stakeholders → Actions
9. Add new Action (if desired)
10. Select Assigned Actions
11. Add new Measure to Assigned Actions
