How to add a GeoTIFF to a measure
Adding a GeoTIFF to a measure allows for the evaluation of different scenarios for a height map. For example, to evaluate the impact of a wadi on water stress, or the impact of a sound wall on noise pollution.
How to add a GeoTIFF to a measure:
- With a project opened in the editor, select Future Design
- Open the measures panel by clicking on Measures in the ribbon bar.
- Add a new or select an existing measure.
- With the measure selected, click on the button Add GeoTIFF which can be found in the lower part of the left panel.
- In the GeoTIFFs detail panel, click on the Add button.
- The GeoTIFF selection panel now opens.
- If you want to import new GeoTIFFs from your computer or from the GeoShare, you can now do so.
- Once done importing, select one or more GeoTIFFs and confirm.
- The selected GeoTIFFs should now show up in the GeoTIFF detail panel.
- Notice the checkbox below named "Calculate Area from GeoTIFFs automatically".
- If you want to manually restrict the area where this TiffSpatial is applied, uncheck this option. Next, click on the button below the checkbox to manually draw an area for the GeoTIFF. The TiffSpatial's GeoTIFFs will only be applied within that area when activating this measure.
- Otherwise, the MultiPolygon for the GeoTIFF Spatial is automatically calculated by the Tygron Platform once the GeoTIFF changes are send to the server. This calculation might take a while depending on the amount and complexity of GeoTIFFs supplied.
The measure panel with a TiffSpatial.
The spatial detail panel with automatic calculation checked.
Select one or more GeoTIFFs in the GeoTIFF selection panel.
The situation before applying the measure. It is almost flat.
The situation after applying the measure. It is now raised and curved.
The situation when adding buildings on top of the TiffSpatial.
- You can add more than one GeoTIFF to a TiffSpatial of a measure.
- Multiple GeoTIFFs can be selected by using shift and ctrl in the GeoTIFF selection panel.
- You can manually provide the MultiPolygon for which the GeoTIFFs are applied.
- You can practice this using the DXF demo project
