Measure
A measure can be used to:
- Place Buildings. These buildings will be linked to the measure;
- Execute terrain adjustments. Stored in measure as TerrainSpatials;
- Apply changes in elevation using Grids or GeoTIFFs. Stored in measure as GridSpatials and TiffSpatials;
- Upgrade existing Buildings that overlap the defined upgrade selection; Stored in measure as UpgradeSpatials;
- Place Levees with side and top Functions; Stored in measure as LeveeSpatials;
- Execute Server events. Stored in measure with two lists: one for when measure is constructed and one for when measure is cancelled.
These actions are configured as spatial components of the measure, spatials in short. There are restrictions on which of these spatials may overlap, in order to keep the measure consistent. For example, two Buildings that are on the same layer cannot overlap. However, other spatial combinations are allowed to overlap. For example, Buildings can be placed on top of GeoTIFF and Terrain spatials.
A measure can be owned by a specific Stakeholder. You can change its name, description, image, cost and construction details. However, a measure can also be performed by other stakeholders, which may override the Stakeholder originally specified.
A measure is an action, which means it can be added to an Action Menu. Also, measures can be activated indirectly using events. Thirdly, they can be activated directly in the editor by clicking on the Activate Measure link:
When to use measures
A measure can be used to offer predefined plans to stakeholders. When a plan exists, applicable to the case implemented in the project, that plan can be implemented as a measure. Such a plan can consist of the spatial components of the plan, as well as specific costs, and other eventual consequences of implementing that plan.
A measure does not need to have a spatial components. Instead, it can also be used to represent a policy change or campaign, which may have consequences for indicators, or may trigger events.
Advanced usage of measures
Not showing spatial effects
Reusing measures
Using the above principle, it is also possible to reuse measures. If multiple measures would have the same spatial effect, it is possible to have an additional measure in which the actual spatial effect is defined. All measures which should have that spatial effect can trigger the additional measure. This has the benefit of being easier to maintain if the spatial effect needs to change. Any change to the plan would only require a change to a single measure, instead of all measures which have the same effect.
- Measure is a Sourced Item, which means it records which Sources created it and which Sources changed any of its properties.
- How to add and remove measures
- How to add and remove Buildings to a measure
- How to edit general measure properties
- How to edit measure cost details
- How to edit measure events
- How to edit spatial components of a measure
- How to add a Grid to a Measure
- How to add a GeoTIFF to a measure
- How to import a measure with water
- How to level terrain in Measures
- How to add an Area to a Measure
- How to import AutoCAD DXF files
- How to import an IFC file
- How to import a GeoPackage file
- How to edit a Measure with QGIS
- How to add a Levee Spatial to a Measure
- How to edit properties of a Levee Spatial
- Buildings
- GridSpatials
- LeveeSpatials
- TerrainSpatials
- TiffSpatials
- UpgradeSpatials
- Demo Dxf Import Project
