A Breach area can be used to simulate a breach in a levee or dam. It is identified via the BREACH_HEIGHT attribute. Water flowing through the breach originates from a body of water. This body of water can be defined as an input area in the project or a conceptual external water body existing outside the project area. Water can flow through the breach from the input water body to the defined Breach area, and vice versa.
| Icon |
Key |
Unit |
Range |
Description |
Default value |
BREACH_HEIGHT |
m + datum |
-10000 to 10000 |
The new terrain height at the location of the breach. |
0 |
BREACH_WIDTH |
m |
0 to 10000 |
The initial width of the breach. |
2 |
BREACH_ANGLE |
geo angle (0-360°) |
-1.7976931348623157E308 to 1.7976931348623157E308 |
The angle at which water flows out through the breach. |
n/a |
BREACH_COEFFICIENT |
coefficient |
0 to 3.4028235E38 |
The flow coefficient related to the shape of the breach. |
1.37 |
BREACH_SPEED |
m/s |
0 to 3.4028235E38 |
The critical speed factor in the breach width growth formula (e.g. 0.2 for sand and 0.5 for clay). A value of 0 or smaller corresponds to zero growth. |
0 |
BREACH_INPUT_AREA |
ID of an Area |
-1 to 2147483647 |
The Area item representing the influx area for the breach. |
none |
BREACH_LEVEL_AREA |
ID of an Area |
-1 to 2147483647 |
The Area item representing the downstream water level measurement area for the breach. |
none |
EXTERNAL_SURFACE_LEVEL |
m + datum |
-10000 to 10000 |
The height of the bottom of the external water body behind the breach. The lowest level the external water level can lower to. |
0 |
EXTERNAL_WATER_LEVEL |
m + datum |
-10000 to 10000 |
The water level of the external water body behind the breach. The initial value assigned to the water level. |
0 |
EXTERNAL_AREA |
m² |
The surface area of the external water body behind the breach. The larger the external water body, the more water can flow from it (or into it), and the smaller the effect of the inflow or outflow of water on the external water level. When provided with a second value, this key will also define a bottom area for the external water body, transforming its cross-section from a rectangle to a trapezoid. |
n/a |
Overlay attributes
| Icon |
Attribute |
Unit |
Range |
Description |
Default value |
BREACH_MEASUREMENT_DISTANCE_M |
m |
0 to 10000 |
Distance from the breach area to the automatic downstream water level measurement point, in the direction of the breach. |
100 |
- Breaches can only be configured for Flooding Overlays.
- Overlapping Breaches are not allowed. Should in any location two or more Breaches overlap, the values of one of them is used, and the values of the others are ignored.
