Model attributes (Water Overlay)
Revision as of 11:32, 6 December 2019 by Godelief@tygron.nl (talk | contribs)
The water overlay's model calculations depend on a number of calculation-wide parameters. These parameters are available as attributes of the water overlay and can be modified as such.
Icon Attribute Unit Description
Waterwizard icon allowed water increase.png ALLOWED_WATER_INCREASE_M m The amount by which the water level on a water terrain must increase before it is considered stressed by water. This is used to compute the WATER_STRESS result type.
CULVERT_DEM_THRESHOLD_M m The maximum distance a culvert's height can be below the terrain, for the terrain height to be adjusted to the height of the culvert.
GRAVITY m/s² Used constant for gravitational acceleration.
GROUND_WATER boolean Whether water in the underground is simulated during the calculation. If this is deactivated, surface and underground infiltration, and underground evaporation do not occur. Water flowing in- and out of the sewer are still simulated when sewers are present.
Waterwizard icon allowed water increase.png IMPACT_FLOOD_THRESHOLD_M m The amount of water a construction must experience before it is considered impacted by water. Water must reach this height either on one of the cells the construction is on, or on one of the cells adjacent to it. This is used to compute the IMPACTED BUILDINGS result type.
INFILTRATION boolean Whether surface water can infiltrate into the unsaturated zone of the ground layer.
LIMIT_RAIN boolean Whether rainfall locations should be limited to water level areas, or rainfall will fall in the entire project area.
MAX_WATER_BOTTOM_M m + datum The maximum height for the bottoms of water terrains. Any water terrain with a bottom at a higher datum height has its bottom lowered to this value.
MAX_WATER_DEPTH_M m The maximum depth of water on a cell that is able to move horizontally. This parameter can be set to influence the wave part in the Saint-Venant equations.
MINIMAL_CULVERT_DIAMETER_M m
OBJECT_CORRECTION boolean Objects (culverts, pumps, weirs) sometimes overlap each other and then one object becomes inactive. When this happens the rasterizer automatically moves the object start/end point by a maximum of one cell so both object are connected.
SEWER_OVERFLOW_THRESHOLD fraction (m/m) How much of a sewer's storage must be filled with water before the sewer's overflows are allowed to overflow water.
SHORELINE boolean When a Waterway polygon is not correctly positioned in relation to the DEM this can result in filling up the nearby land with water at the start of the simulation. This will result in a lower water level then is expected from the water level area value. To correct this, a "shoreline" is added at neighbouring cells. At the start of the simulation, these shoreline cells will also be filled with water up to the nearby water level to prevent the initial flush. By default this option is turned on, but can be turned off by changing the attribute to 0.
Waterwizard icon allowed water increase.png SHOW_DURATION_FLOOD_LEVEL_M m The amount of water which must be present in a specific location before the duration of surface water can be recorded. This is used to compute the SURFACE_DURATION result type.
TIMEFRAMES integer The number of intermediate results recorded during the calculation. Each timeframe becomes a snapshot of data which can be viewed and analysed.
