Terrain water storage percentage (Water Overlay)
| Icon | Attribute | Unit | Layer | Range | Description |
WATER_STORAGE_PERCENTAGE | fraction (m3/m3) | Ground | The percentage (as a fraction) of the ground layer volume which can be filled with water. A lower percentage means the ground layer will be able to store less water, and the saturated zone will rise higher with the same amount of water in the ground layer. |
Based on the properties of the terrain, water may infiltrate into the ground layers. Two ground layers are distinguished; the unsaturated zone and saturated zone.
The speed at which water can infiltrate from the surface to the unsaturated zone is dependent on both the GROUND_INFILTRATION_MD of the surface terrain, as well as the GROUND_INFILTRATION_MD of any building in that location, if present. The grid cell uses the lowest infiltration value among the building (if present), the surface terrain, and the ground terrain. If any of these values is 0, water cannot infiltrate into the unsaturated zone.
The maximum amount of water which can be stored in the saturated zone is based on the WATER_STORAGE_PERCENTAGE of the ground terrain.
Ground flow, also known as horizontal infiltration, is also dependent on the infiltration properties of the ground layer, unless an aquifer exists in the same location.
- Contrary to its name, the WATER_STORAGE_PERCENTAGE should always be a fraction.
- The groundwater level reduction is related inversely to the WATER_STORAGE_PERCENTAGE, as the contribution of a given volume of water to the groundwater level increases when the capacity for water storage in the ground layer decreases.
- Groundwater level formula (Water Overlay)
- Ground infiltration formula (Water Overlay)
- Ground model (Water Overlay)
- Evapotranspiration model (Water Overlay)
- Infiltration model (Water Overlay)
- Trim ground storage fraction (Water Overlay)
