Object entry correction (Water Overlay)
(Redirected from Object correction (Water Overlay))
OBJECT_ENTRY_CORRECTION | cells | 0 to 3 cells | Number of cells allowed to move a hydraulic structure's entry and exit points when they overlap with another hydraulic structure. | 2 |
Entry and exit points of hydraulic structures, such as culverts, pumps and weirs, can sometimes overlap each other. When this happens the rasterizer automatically moves the entry/exit point(s) by a maximum number of cells such that the object(s) can operate.
- This Attribute is by default set to 2 which means object correction is applied.
- 3 cells is the maximum allowed for this Attribute.
- In the advanced settings step of the Water Overlay Wizard, this Attribute can also be (de)activated.
