Ground bottom pressure m (Water Overlay)
The ground bottom pressure m setting can be configured in the Bottom boundary step of a Water Overlay wizard, when the ground water mode set to Complete.
This optionally fluctuating bottom pressure is added to the spatially defined Bottom pressure, and together with the bottom resistance used to calculate ground bottom flow.
This attribute can be defined as values over time, using an array of values, defined as pairs of the start-time and its value from that point on.
