Timestep formula (Water Overlay)
- the timestep is chosen so that all computation cells follow one of the following criteria..
- if a cell's water depth is below the flooding threshold of 5 × 10-3 m, no flow is assumed between that cell and its neighboring cells.
- If the cell's water depth is above the flooding threshold, the maximum timestep is assumed to be 100 × the water depth at that cell.
- ↑ 1.0 1.1 A Second-Order Well-Balanced Positivity Preserving Central-Upwind Scheme for the Saint-Venant System ∙ Kurganov A, Petrova G (2007) ∙ Page(s): 15 ∙ Found at: https://people.tamu.edu/~gpetrova//KPSV.pdf ∙ (last visited: 2016-02-25)
