Api session event editor panel
API Endpoint: api/session/event/editorpanel/
API Endpoints for Panel editing.
Name Description
add Add a Panel of a particular Type
append_attribute Appended to existing Panel numeric Attribute value
duplicate Duplicate existing Panel
remove Remove existing Panel
remove_attribute Remove numeric Attribute from Panel
set_attribute Set Panel numeric Attribute value
set_attributes Set multiple Panel numeric Attribute values
set_name Set the name of a Panel
Additional API Endpoints:
Name Description
add_answer Add an Answer to a Panel
add_answer_event Add a Server or Clientside Event to an Answer of a Panel
add_global Add Globals to a Global Panel
add_overlay_template Add a Template Excel Panel associated with an Overlay using a Panel Template
add_template Add a Template Excel Panel using a Panel Template. Also adds a new Overlay when associated
apply_template_panels Apply each provided Template (Excel Sheet / Text) Panel, after removing previous instances
duplicate_answer Duplicate an Answer of a Panel
edit_answer_event Replace the Coded Event of a Server or Clientside Event of an Answer of a Panel, using the Coded Event ID
export_debug_excel Export an Excel Sheet, populated with data related to the Excel Panel, to Byte array content
export_excel_call_tree Export a performance report of an Excel Sheet, populated with data related to the Excel Panel, to text as Byte array content
import_wikipedia_points Add a positioned Web Panel for each identified Wikipedia Point of Interest
remove_answer Remove an Answer from a Panel
remove_answer_event Remove a Coded Event of a Server or Clientside Event of an Answer of a Panel
remove_global Remove Globals from a Global Panel
remove_overlay Remove the Overlay association from a Panel
set_answer_contents Set the text content of an an Answer of a Panel
set_attention Set whether the Panel requires attention
set_excel Set the Excel Sheet used by a (Template) Excel Panel
set_excel_update_timing Set the calculation Timing of an Excel Panel
set_for_everyone Set a Panel accessible by each Stakeholder
set_for_stakeholder Set a Panel only accessible to a particular Stakeholder
set_layout_xy Set the interface position of a Panel
set_overlay Set the Overlay associated by a Panel
set_point Set the position of a Panel
set_size Set the interface size of a Panel
set_template_apply_automatically Configure whether the specified Template Panels are automiticatelly reapplied at the start of a Session
set_template_attribute Set which Attribute is used by a Template Panel to create Panel instances
set_template_panel_maplink Set which Maplink is used by a Template Panel to create Panel instances
set_template_relation Set which Relation is used by a Template Panel to create Panel instances
set_template_use_owner Set whether Panel instances of a Template Panel are owned by Stakeholders of their associated Maplink Items. (When false, Template Panel Stakeholder is used)
set_text Set the text content of a (Template) Text Panel
set_url Set the URL of a Web Panel
set_visible Set whether a Panel is visible in the 3D Visualization
