Api session event editor panel import wikipedia points
API Endpoint: api/session/event/editorpanel/import_wikipedia_points/
Description: Add a positioned Web Panel for each identified Wikipedia Point of Interest
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorpanel/import_wikipedia_points/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''JavaScript example POST
body: ''
fetch("https://engine.tygron.com/api/session/event/editorpanel/import_wikipedia_points/", options)
