Api session event editor panel set url
API Endpoint: api/session/event/editorpanel/set_url/
Description: Set the URL of a Web Panel
0 REQUIRED (PANEL Integer ID) Web Panel
1 REQUIRED (String) URL
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "URL" ]'
JavaScript example POST
 body: '[ 1, "URL" ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_url/", options)
