Api session event editor panel set overlay
API Endpoint: api/session/event/editorpanel/set_overlay/
Description: Set the Overlay associated by a Panel
| 0 | REQUIRED | (PANEL Integer ID) | Panel | |
| 1 | REQUIRED | (OVERLAY Integer ID) | Overlay |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_overlay/", options)
