Api session event editor panel apply template panels
API Endpoint: api/session/event/editorpanel/apply_template_panels/
Description: Apply each provided Template (Excel Sheet / Text) Panel, after removing previous instances
0 REQUIRED (PANEL Integer ID or multiple integer values in array [1, 2, 3]) Template Panels
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/apply_template_panels/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorpanel/apply_template_panels/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorpanel/apply_template_panels/", options)
