Api session event editor panel remove overlay
API Endpoint: api/session/event/editorpanel/remove_overlay/
Description: Remove the Overlay association from a Panel
0 REQUIRED (PANEL Integer ID) Panel
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/remove_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorpanel/remove_overlay/", options)
