Api session event editor panel set template relation
API Endpoint: api/session/event/editorpanel/set_template_relation/
Description: Set which Relation is used by a Template Panel to create Panel instances
0 REQUIRED (PANEL Integer ID) Panel
1 OPTIONAL (Enumeration) Maplink
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_template_relation/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_template_relation/", options)
