Excel Sheet
Excel Sheet is an Item that stores data of an Excel File.
Properties
An Excel Sheet item has the following properties:
  • Byte array of the Excel File contents
  • Name of the file; Limited to lowercase with underscores.
  • Uploader name and date
  • Warnings from Simulation Core
  • Optional certification:
    • Certificate Author
    • Certificate Path
    • Certificate State: NONE, CERTIFIED, UNCERTIFIED
Simulation Core Instances
A single Excel Sheet can be referenced by multiple Panels and Indicators. Indicator and Panel calculators can fill their instance of an Excel Sheet with their specific TQL Queries. A specific TQL query example is: SELECT_NAME_WHERE_INDICATOR_IS_ID
  • Contrary to its name, an Excel Sheet item can hold the contents of an Excel file with multiple sheets.
  • An Excel Sheet cannot be removed while it is referenced by a Panel or Indicator.
API Endpoints
