Api session event editor panel set template attribute
API Endpoint: api/session/event/editorpanel/set_template_attribute/
Description: Set which Attribute is used by a Template Panel to create Panel instances
| 0 | REQUIRED | (PANEL Integer ID) | Panel | |
| 1 | REQUIRED | (String) | Attribute |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_template_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute" ]'JavaScript example POST
body: '[ 1, "Attribute" ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_template_attribute/", options)
