Api session event editor panel edit answer event
API Endpoint: api/session/event/editorpanel/edit_answer_event/
Description: Replace the Coded Event of a Server or Clientside Event of an Answer of a Panel, using the Coded Event ID
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (Integer number) Answer ID
2 REQUIRED (true, false) Server side true or false
3 REQUIRED (CodedEvent) Coded Event
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/edit_answer_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, true, {
 "id" : -1,
 "parameters" : [ ]
JavaScript example POST
 body: '[ 1, 1, true, { "id" : -1, "parameters" : [ ]} ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/edit_answer_event/", options)
