Api session event editor panel duplicate answer
API Endpoint: api/session/event/editorpanel/duplicate_answer/
Description: Duplicate an Answer of a Panel
0 REQUIRED (PANEL Integer ID or multiple integer values in array [1, 2, 3]) Panels
1 REQUIRED (Integer number or multiple integer values in array [1, 2, 3]) Answer IDs
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/duplicate_answer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorpanel/duplicate_answer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/duplicate_answer/", options)
