Api session event editor panel set template use owner
API Endpoint: api/session/event/editorpanel/set_template_use_owner/
Description: Set whether Panel instances of a Template Panel are owned by Stakeholders of their associated Maplink Items. (When false, Template Panel Stakeholder is used)
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (true, false) Use Maplink's associated Stakeholder true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_template_use_owner/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_template_use_owner/", options)
