Api session event editor panel set template apply automatically
API Endpoint: api/session/event/editorpanel/set_template_apply_automatically/
Description: Configure whether the specified Template Panels are automiticatelly reapplied at the start of a Session
| 0 | REQUIRED | (PANEL Integer ID or multiple integer values in array [1, 2, 3]) | Template Panels | |
| 1 | REQUIRED | (true, false) | Apply automatically | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_template_apply_automatically/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_template_apply_automatically/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], true ]'JavaScript example POST
body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_template_apply_automatically/", options)
