Api session event editor panel set size
API Endpoint: api/session/event/editorpanel/set_size/
Description: Set the interface size of a Panel
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (Floating point number) Width
2 REQUIRED (Floating point number) Height
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_size/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 85, 77 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_size/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 13, 0 ]'
JavaScript example POST
 body: '[ 1, 85, 77 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_size/", options)
