Api session event editor panel set visible
API Endpoint: api/session/event/editorpanel/set_visible/
Description: Set whether a Panel is visible in the 3D Visualization
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (true, false) Visible true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_visible/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_visible/", options)
