Ground bottom flow formula (Water Overlay)
Revision as of 12:08, 12 November 2026 by Frank@tygron.nl (talk | contribs)
Ground water flowing in from deeper ground layers through the bottom boundary, due to head pressure from water bodies situated outside the project area is calculated per grid cell. The formula is based on the principles used in the formula of Pankow for estimating this ground bottom flow[1].
The water level change due to ground bottom flow is calculated using the following formula:
Δwlc,t=hd(t)−hc,tcc,tf⋅Δt24⋅60⋅60
The external bottom head pressure is variable over time by the introduction of hv(t):
hd(t)=pc,tf+hv(t)
Finally, the actual amount of water flowing into the ground from the deeper ground layers through the bottom boundary is calculated as follows:
Δsc,t=Δwlc,t⋅wsc
Δwlc,t = The water level change due to the ground bottom flow at time t and cell c, in meters.
hc,t = Ground water head at cell c and time t.
hd(t) = Additional global pressure at time t, in meters.
pc,tf = Ground water level (or head pressure) in meters at timeframe tf and cell c.
hv(t) = Additional variation of bottom head pressure over time.
cc,tf = Resistance of the bottom boundary in days at timeframe tf and cell c.
wsc = Water storage fraction of the soil at cell c.
Δsc,t = The amount of ground bottom flow through the bottom boundary from deeper ground layers, in m, at time t and cell c.
  • The calculated Δwlc,t is essentially the change in groundwater level (saturated zone height). The final Δsc,t, obtained by multiplying with the water storage fraction, represents the actual amount of water added, i.e. the equivalent height of that water if it sat on the surface instead of being stored in the ground.
  • pc,tf and cc,tf can both be provided as spatially variable values using prequel overlays. These prequels can have multiple timeframes, as indicated by the formula, allowing changing head and resistances over time.
  • The additional variation of bottom head pressure hv(t) can be provided as a set of values that vary over time.
  • A head pressure lower than the water level in the project is also allowed, resulting in a lowering of the ground water level, with water flowing into the deeper ground layers and out of the project area.
Groundwater level formula (Water Overlay)
Models
Ground model (Water Overlay)
  1. ↑ Estimating ground bottom flow ∙ Found at: http://grondwaterformules.nl/index.php/formules/ontwatering/kwel-berekenen-pankow ∙ (last visited: 2020-09-02)
