Api session event editor panel
API Endpoint: api/session/event/editorpanel/
API Endpoints for Panel editing.
| Name | Description |
| add | Add a Panel of a particular Type |
| append_attribute | Appended to existing Panel numeric Attribute value |
| duplicate | Duplicate existing Panel |
| remove | Remove existing Panel |
| remove_attribute | Remove numeric Attribute from Panel |
| set_attribute | Set Panel numeric Attribute value |
| set_attributes | Set multiple Panel numeric Attribute values |
| set_name | Set the name of a Panel. |
Additional API Endpoints:
| add_answer | Add an Answer to a Panel |
| add_answer_event | Add a Server or Clientside Event to an Answer of a Panel |
| add_global | Add Globals to a Global Panel |
| add_overlay_template | Add a Template Excel Sheet Panel associated with an Overlay using a Panel Template |
| add_template | Add a Template Excel Sheet Panel using a Panel Template. Also adds a new Overlay when associated. |
| apply_template_panels | Apply each provided Template (Excel Sheet / Text) Panel, after removing previous instances |
| duplicate_answer | Duplicate an Answer of a Panel |
| edit_answer_event | Replace the Coded Event of a Server or Clientside Event of an Answer of a Panel, using the Coded Event ID |
| export_debug_excel | Export an Excel Sheet, populated with data related to the Excel Sheet Panel, to Byte array content |
| export_excel_call_tree | Export a performance report of an Excel Sheet, populated with data related to the Excel Sheet Panel, to text as Byte array content |
| import_wikipedia_points | Add a positioned Web Panel for each identified Wikipedia Point of Interest |
| remove_answer | Remove an Answer from a Panel |
| remove_answer_event | Remove a Coded Event of a Server or Clientside Event of an Answer of a Panel |
| remove_global | Remove Globals from a Global Panel |
| remove_overlay | Remove the Overlay association from a Panel |
| set_answer_contents | Set the text content of an an Answer of a Panel |
| set_attention | Set whether the Panel requires attention |
| set_excel | Set the Excel Sheet used by a (Template) Excel Sheet Panel. |
| set_excel_update_timing | Set the calculation Timing of an Excel Sheet Panel |
| set_for_everyone | Set a Panel accessible by each Stakeholder. |
| set_for_stakeholder | Set a Panel only accessible to a particular Stakeholder. |
| set_layout_xy | Set the interface position of a Panel. |
| set_overlay | Set the Overlay associated by a Panel |
| set_point | Set the position of a Panel |
| set_size | Set the interface size of a Panel. |
| set_template_apply_automatically | Configure whether the specified Template Panels are automiticatelly reapplied at the start of a Session. |
| set_template_attribute | Set which Attribute is used by a Template Panel to create Panel instances |
| set_template_panel_maplink | Set which Maplink is used by a Template Panel to create Panel instances |
| set_template_relation | Set which Relation is used by a Template Panel to create Panel instances |
| set_template_use_owner | Set whether Panel instances of a Template Panel are owned by Stakeholders of their associated Maplink Items. (When false, Template Panel Stakeholder is used) |
| set_text | Set the text content of a (Template) Text Panel. |
| set_url | Set the URL content of a Web Panel. |
| set_visible | Set whether a Panel is visible in the 3D Visualization. |
