Point-based building (Water Overlay)
Point based buildings are constructions for which their geometry is interpreted as a single point.
Examples of point based buildings are the following hydraulic structures:
| Icon | Name | Description |
| Inlet | Conditional flow from external area to inlet location. | |
| Sewer overflow | Conditional flow from sewer to waterway, based on sewer overflow height. |
Center point
One way to obtain a point from a geometry is by calculating its geometric center. The method used by Tygron Platform is similar to [1]. See the following examples:
This method may have limitations depending on the complexity of the geometry. See the following two cases:
In case one, the building's geometry is a complex polygon. Its centroid lies outside its geometry.
In case two, the building's geometry is a multi-polygon. Its centroid is in between the two rectangle polygons.
Generally, these kind of polygons are undesirable for a point-based building.
General advice
- The point-based buildings should be supplied as simple rectangle or circular polygons.
- The geometry should consist of only one polygon. In the case of buildings, use only one section.
