Evapotranspiration model (Water Overlay)
Evapotranspiration is the combined process of water transferring to the atmosphere from open water and vegetation. Two types are implemented:
- Evaporation: the movement of water directly to the air from sources such as the soil and water bodies. It can be affected by factors including heat, humidity, solar radiation and wind speed.
- Transpiration: the movement of water from root systems, through a plant, and exit into the air as water vapor.
Both forms can be configured directly by setting the weather's evaporation rate. The weather's evaporation rate is defined as a period during which a certain rate of evaporation will take place, similar to rainfall. Multiple evaporation periods can be defined. The general evaporation amount per period is converted to an amount per second.
In case less water is present at a particular grid cell, the amount of evaporation will be less than the maximum possible evaporation at the time in the simulation. The remainder will not be carried over to the next time step and will therefore always be discarded.
The default setup for evaporation consists of a single period of evaporation and an evaporation amount. It is possible to configure an evaporation rate which varies over time. More periods with varying amounts of evaporation (including an evaporation rate of zero) can be defined.
Surface Evaporation
Ground Transpiration
Water can transpire from the ground if the cell's surface meets either of the following criteria:
- A building on the surface
- The building has a non-zero WATER_TRANSPIRATION_FACTOR.
- The building has a non-zero root depths.
- No building on the surface
- The surface terrain type has a non-zero WATER_TRANSPIRATION_FACTOR.
- The surface terrain type has a non-zero root depths.
In other words: if a building is present the building's properties are used, otherwise the terrain's properties are used.
Feddes factor
Conceptually, water can transpirate from the ground via crop, tree and plant foliage. Their roots can draw water from the unsaturated and saturated zones in the ground, when these reach deep enough and the transpiration factor is non-zero. Water is drawn from the ground and transpired into the air, effectively removing it from the hydrological model. Water for transpiration can only be drawn from sections of the ground which are within reach of the roots, as defined by the root depth. Using the multiple root depth values, it is also possible to define a threshold at which the roots are unable, or less able, to extract ground water, due to oxygen stress. In such cases, up to four root depth values must be provided, ordered from deepest to shallowest.
Seasonal factor
The ground evaporation can be configured directly by changing the terrain type's WATER_TRANSPIRATION_FACTOR and building's WATER_TRANSPIRATION_FACTOR. If these attributes are set to 0, no ground evaporation will take place. This attribute can also be set as 4 distinct values, one for each growth season. This allows for more transpiration during a crops growth season and less during the winter.
Varying transpiration rate
Similar to the surface evaporation, the rate of ground transpiration is also determined by the weather definition's evaporation rate. Multiplying the weather's evaporation rate and the transpiration factor of the building or terrain (as applicable) gives the actual transpiration rate for the ground.
Ground transpiration first draws water from the unsaturated region and then from the saturated region. If, according to the calculated transpiration rate, a sufficient amount of water can transpirate from the unsaturated zone, no water will transpirate from the saturated zone. Otherwise, available water in the unsaturated zone is transpired first, with any remaining requirement drawn from the saturated zone. The sum of transpiration in the unsaturated zone and the saturated zone will never exceed the calculated transpiration rate.
Example for dynamic evaporation
See the table below for an example of dynamic transpiration:
| Time key (minutes) | Evaporation rate (mm/d) |
| 35 | 1.5 |
| 42 | 1.9 |
| 120 | 0.5 |
- The first period starts at t=0 minutes and ends at t=35 minutes. In this first period, water will evaporate at a rate of 1.5 mm per day. Uniformly this gives 1.5 / (24 * 60 * 60) = 0.000017 mm per second.
- The second period starts at t=35 minutes and ends at t=42 minutes. In this period, water will evaporate at a rate of 1.9 mm per day. Uniformly this is 1.9 / (24 * 60 * 60) = 0.000022 mm per second.
- The last period starts at t=42 minutes and ends at t=120 minutes. In this period, water will evaporate at a rate of 0.5 mm per day. Uniformly this is 0.5 / (24 * 60 * 60) = 0.000006 mm per second.
In total it can be expected that 1.5 * ( (35-0) / (24*60) ) + 1.9 * ( (42-35) / (24*60) ) + 0.5 * ( (120-42) / (24*60) ) = 0.036 + 0.009 + 0.027 = 0.0728 mm of water will have evaporated in a total simulation time of 120 minutes.
If available water is less than the calculated evaporation amount for a timestep, only the available water evaporates.
- The configuration wizard is the easiest way to adjust evaporation and rainfall.
- If the weather's evaporation rate is set to 0, no evaporation will take place in any form.
- A period without evaporation can be simulated by setting the evaporation rate for a period to zero.
- An evaporation rate of zero is allowed, but a negative evaporation rate is not. Negative evaporation rate is treated as zero.
- Ground evaporation will only take place when the ground model is active.
- The evaporation table is stored as the attribute array with the name EVAPORATION_M. This attribute is part of the weather definition associated with the Water Overlay.
- The underlying attribute array defines time in seconds.
- The next time key should always be larger than the previous time key.
- If the next time key for the evaporation rate is smaller than the previous time key for rainfall, the previous rate of evaporation is continued until the end of the simulation.
- Ground transpiration result type (Water Overlay)
- Surface evaporation result type (Water Overlay)
- Evapotranspiration result type (Water Overlay)
- Ground last transpiration result type (Water Overlay)
- Surface last evaporation result type (Water Overlay)
- Last evapotranspiration result type (Water Overlay)
