Elevation model (Water Overlay)
Revision as of 10:48, 13 October 2026 by Frank@tygron.nl (talk | contribs)
The elevation model is determined using two steps:
  • Rasterization of the height sectors and buildings
  • Piecewise linear reconstruction of the bottom
Rasterization of height points of height sectors and buildings
The base land height values can originate from two sources:
Often the height source has more height values for a particular grid cell. The calculated height value for that grid cell is then determined as the average of these points.
Added to the rasterized land height are the height of solid buildings. A building's height is calculated based on the floor height times the amount of floors and optional height offset. In case a building has a Custom Geometry, the height is calculated based on this custom geometry, within the boundaries of the grid cell, with the addition of the optional height offset. The calculated height of a building (including bridges!) is limited by the value configured for the design flood elevation model attribute.
How bridges are handled as buildings depend on the configured bridge mode.
Furthermore certain conditions, such as a configured Weir Height or Culvert Threshold can override a grid cell elevation. This overriding also provides a preference for the piecewise linear reconstruction.
The implementation of the Water Module is based on second-order semi-discrete central-upwind scheme by Kurganov and Petrova (2007)[1]. The surface elevation, also named bottom in the paper, is slightly adjusted to support the scheme to become well balanced and positivity preserving. The process of adjusting the original surface elevation is called piecewise linear reconstruction of the bottom.
1D linear piecewise reconstruction. Source: Kurganov and Petrova (2007)[1]
The first requirement the scheme to become well balanced and positivity preserving is to ensure that each grid cell has a constant linear slope in both the x- and y- direction. Secondly the end points of the slope should meet in the center of the cell's edges. This ensures that the bottom is continuous along cells in the x- and y- direction. Thirdly, the linear slope in the x- and y-direction within a cell should meet in a single center point.
To fulfill these requirements, the following steps are taken:
  1. Pick or calculate the height points for the 4 corners of the cell. A height point is picked when an override height is provided, such as a Weir Height.
  2. Form a rectangle with the 4 corners and calculate the centers of these edges. (These are the points that have to meet for continuity)
  3. Calculate a new center point based on the 4 edge center points.
Given that the adjacent cells share the same corner points, and thus share an edge center point, the bottom will be continuous in the x and y direction. Furthermore, the cell has an linear slope in both the x- and y-direction. Consequently, the new center point may be higher or lower in situations where the terrain's slope was not originally linear within the cell.
Actions
The following actions influence the rasterized Height Sectors or Buildings, leading to changes in the calculated Elevation model:
  1. ↑ 1.0 1.1 A Second-Order Well-Balanced Positivity Preserving Central-Upwind Scheme for the Saint-Venant System ∙ Kurganov A, Petrova G (2007) ∙ Found at: https://people.tamu.edu/~gpetrova//KPSV.pdf ∙ (last visited: 2026-02-25)
  2. ↑ 2.0 2.1 A two-dimensional numerical scheme of dry/wet fronts for the Saint-Venant system of shallow water equations ∙ Zsolt Horváth, Jürgen Waser, Rui A. P. Perdigão, Artem Konev and Günter Blöschl (2014) ∙ Found at: https://www.tuwien.at/index.php?eID=dumpFile&t=f&f=150915&token=e51c85712b7e70bcb769575d03f4680753d55f01 ∙ (last visited: 2026-02-25)
