Flooding Overlay
Revision as of 14:27, 22 September 2026 by Frank@tygron.nl (talk | contribs) (→Module)
Flooding overlay
The Flooding Overlay is a variant of the Water Overlay, which in turn is a grid overlay. Water overlays are connected to the Water Module, a hydrological calculation module within the Tygron Platform.
The Flooding Overlay calculates and visualizes the movement of water over land, due to a breach or other inflow of water in the project area.
To familiarize yourself with the Flooding Overlay components, check Quadrant 1 of the Water Module Testbed. This Testbed is available to you as a project in the Tygron Platform.
Flooding overlay results
The Flooding Overlay is a Water Overlay that is connected to the Water Module. This Water Module performs two dimensional grid based water simulations for a large set of input data and parameters, configured mostly through a related Water Overlay Wizard. When a simulation finishes, the module stores the result in the Flooding overlay based on the selected result type. Only one result type can be stored per Flooding overlay.
The Water Module can produce multiple unique result types for a single simulation. Additional result type overlays, known as result child overlays, can be added to a particular Water overlay. Again, each child overlay only stores one particular result type.
The Flooding overlay can also store multiple intermediate simulation results, known as timeframes, rather than only the final result.
For the full list of result types, see List of Result Types. For other results, which are not overlay results, but still related to the simulation of a Flooding overlay, see water overlay results
Module
A Flooding Overlay can be configured by opening the Flooding Overlay Wizard. More in-depth information can be found under each of the categories below.
