Ground flow formula (Water Overlay)
Ground flow is different from surface flow, since it has to account for the slowdown and porousness of the medium. In general, horizontal ground flow is calculated using formulas described in Harbaugh 2005[1][2]. However, when an aquifer is present, the Aquifer formula is applied.
The Hydraulic Conductivity formula used depends on the value of the HYDRAULIC_CONDUCTIVITY_WITH_THICKNESS attribute in the Water Overlay:
- A value means Hydraulic Conductivity without Thickness formula will be used.
- A value means Hydraulic Conductivity with Thickness formula will be used.
The flow between the two cells is calculated as:
- = The ground water level of cell at time .
- = the datum height of the surface of cell c, set by the elevation or a Terrain elevation prequel.
- = The ground bottom distance of the cell c, defined by a Bottom distance prequel or a general GROUND_BOTTOM_DISTANCE_M of the Water Overlay.
- = the datum height of the bottom boundary at the edge of interaction between the two cells.
- = The hydraulic conductivity of the cell, defined in HYDRAULIC_CONDUCTIVITY_MD of the ground terrain.
- = Area of conductance at time .
- = Ground water level difference at time .
- = Computational timestep in seconds.
- = Size of grid cell.
- = Averaged ground water level at time , based on water levels in ground, WATER_STORAGE_PERCENTAGE and potentially the surface water level, when the ground is filled to the top.
- = The amount of water to be transported at time between one cell and the other.
- = The hydraulic conductivity of the cell, multiplied with the thickness of the layer, defined in HYDRAULIC_CONDUCTIVITY_WITH_THICKNESS_MD of the ground terrain.
Aquifer formula
When an aquifer is present, its hydraulic diffusivity is used to calculate the water flow.
Based on conditions being true, the calculated volume of water that is transported through the aquifer is calculated as:
Where:
- = Ground water level difference between the two adjacent cells at time ;
- = The AQUIFER_KD attribute of aquifer.
- = Ground water level in cell at time ;
- = the datum height of the aquifer at the cell.
- = The calculated amount of water to be transported at time between one cell and the other.
- = Volume in that flows between the two adjacent cells due to the aquifer at time .
Related
- Features
- Aquifer (Water Overlay)
- Formulas
- Groundwater level formula (Water Overlay)
- Ground infiltration formula (Water Overlay)
- Models
- Ground model (Water Overlay)
- Infiltration model (Water Overlay)
- Tracer flow model (Water Overlay)
- ↑ MODFLOW-2005, the U.S. Geological Survey modular ground-water model-the Ground-Water Flow Process: U.S. Geological Survey Techniques and Methods 6-A16 ∙ >Harbaugh, A.W., 2005 ∙ Page(s): various
- ↑ Documentation for the MODFLOW 6 Groundwater Flow Model: U.S. Geological Survey Techniques and Methods ∙ Langevin, C.D., Hughes, J.D., Banta, E.R., Niswonger, R.G., Panday, Sorab, and Provost, A.M. (2017) ∙ Page(s): 31, of book 6, chapter A55 ∙ Found at: https://pubs.usgs.gov/publication/tm6A55 ∙ (last visited: 04-02-2025)
