Culvert threshold (Water Overlay)
CULVERT_THRESHOLD | m + datum | -10000 to 10000 | The height of the inner side of the culvert's underside (or the threshold height at which water starts flowing through the culvert). Each end-point of a culvert will be put on the threshold height or the terrain height at that end-point, whichever value is the highest. | -10000 |
- By default, since the default value is the minimal surface value, each end-point of a culvert is put on the bottom of the waterway at that end-point, determined by terrain height.
- The height at which the end-point of a culvert is situated is stored as the 5th and 6th value of the OBJECT_WATER_AREA_OUTPUT array.
- The Culvert threshold supports only one value, not one for each end-point.
