Inlet capacity (Water Overlay)
Revision as of 15:09, 14 November 2025 by Frank@tygron.nl (talk | contribs)
  • This attribute name is used for both Inlets and pumps.
  • The capacity is a total allowed amount during the entire simulation. When the capacity is reached, no further water can flow through unless water flows in the opposite direction first.
  • If the value is set to 0, there is no limit to this building's capacity.
