Ground flow formula (Water Overlay)
Ground flow is different from surface flow, since it has to account for the slowdown and porousness of the medium. In general, horizontal ground flow is calculated using formulas described in Harbaugh 2005[1][2]. However, when an aquifer is present, the Aquifer formula is applied.
It depends on the configuration of the HYDRAULIC_CONDUCTIVITY_WITH_THICKNESS attribute value in the Water Overlay what Hydraulic Conductivity formula is used:
Hydraulic Conductivity without Thickness
Two adjacent cells, where ground water level of cell 1 is larger than cell 2.
The flow between the two cells is calculated as:
Δwt=w1,tw2,t
Bbb=max(B1db,1,B2db,2)
Ac,t=Δx(wt¯Bbb)
K=min(K1,K2)
VK,t=ΔwKAc,tΔxΔt
wn,t = The ground water level of cell n at time t.
Bc = the datum height of the surface of cell c, set by the elevation or a Terrain elevation prequel.
db,c = The ground bottom distance of the cell c, defined by a Bottom distance prequel or a general GROUND_BOTTOM_DISTANCE_M of the Water Overlay.
Bbb = the datum height of the bottom boundary at the edge of interaction between the two cells.
Kn = The hydraulic conductivity of the cell, defined in HYDRAULIC_CONDUCTIVITY_MD of the ground terrain.
Ac,t = Area of conductance at time t.
Δw = Ground water level difference at time t.
Δx = Size of grid cell.
wt¯ = Averaged ground water level at time t, based on water levels in ground, WATER_STORAGE_PERCENTAGE and potentially the surface water level, when the ground is filled to the top.
VK,t = The amount of water to be transported at time t between one cell and the other.
Hydraulic Conductivity with Thickness
Δwt=w1,tw2,t
KD=min(KD1,KD2)
VKD,t=ΔwKDΔxΔxΔt
KDn = The hydraulic conductivity of the cell, multiplied with the thickness of the layer, defined in HYDRAULIC_CONDUCTIVITY_WITH_THICKNESS_MD of the ground terrain.
VKD,t = The amount of water to be transported at time t between one cell and the other.
Aquifer formula
When an aquifer is present, its hydraulic diffusivity is used to calculate the water flow.
Based on conditions being true, the calculated volume of water that is transported through the aquifer is calculated as:
Va,t={ΔwtKDaΔxΔxΔtif wn,t>za and KDa>0VK(D),totherwise
Where:
Δwt = Ground water level difference between the two adjacent cells at time t;
KDa = The AQUIFER_KD attribute of aquifer.
wn,t = Ground water level in cell n at time t;
za = the datum height of the aquifer at the cell.
VK(D),t = The calculated amount of water to be transported at time t between one cell and the other.
Va,t = Volume in m3 that flows between the two adjacent cells due to the aquifer at time t.
Features
Aquifer (Water Overlay)
Groundwater level formula (Water Overlay)
Ground infiltration formula (Water Overlay)
Models
Ground model (Water Overlay)
Infiltration model (Water Overlay)
Tracer flow model (Water Overlay)
  1. Harbaugh, A.W., 2005, MODFLOW-2005, the U.S. Geological Survey modular ground-water model-the Ground-Water Flow Process: U.S. Geological Survey Techniques and Methods 6-A16, variously paginated.
  2. Langevin, C.D., Hughes, J.D., Banta, E.R., Niswonger, R.G., Panday, Sorab, and Provost, A.M. (2017) ∙ Documentation for the MODFLOW 6 Groundwater Flow Model: U.S. Geological Survey Techniques and Methods, book 6, chap. A55 ∙ p 31 ∙ found at: https://doi.org/10.3133/tm6A55 (last visited 2019-02-04)
