Ground evaporation formula (Water Overlay)
Revision as of 13:22, 27 February 2024 by Frank@tygron.nl (talk | contribs)
Conceptually, water can evaporate from the ground via crop, tree and plant foliage. This is called evapotranspiration. The amount a plant can evaporate depends on the saturation and ground water level, as well as the root structure. The factor by which roots can extract water from the ground is modeled using the Feddes trapezium.
Feddes trapezium indicating for what water levels and by what factor roots of a plant can extract water from the ground.
The amount a plant, crop or tree evaporates also depends on its growth season. Therefore, the species specific Water evaporation (Function Value can be defined by four seasonal values.
This evaporation is calculated per cell.
For all ground evaporation calculation, the ground water depth at time t is used.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle d_{gw,t} = B_{c} - w_{g,t}}
Feddes oxygen stress factor:
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle f_o = \begin{cases} 1.0 & \text{if } d_{gw,t} \text{ is } \geq d_{r,3} \\ \frac{d_{gw,t} - d_{r,4}}{d_{r,3} - d_{r,4}} & \text{if } d_{gw,t} \text{ is } \geq d_{r,4} \\ 0.0 & \text{otherwise} \end{cases} }
Feddes saturated zone root update factor:
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle f_s = \begin{cases} 0.0 & \text{if } d_{gw,t} \text{ is } \geq d_{r,1} \\ 1.0 - \frac{d_{gw,t} - d_{r,2}}{d_{r,1} - d_{r,2}} & \text{if } d_{gw,t} \text{ is } \geq d_{r,2} \\ 1.0 & \text{otherwise} \end{cases} }
Seasonal transpiration factor:
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle f_{ts,t} = (1.0 - f_{se,t}) \cdot f_{ts,c} + f_{se,t} \cdot f_{ts,n}}
Max potential evaporation:
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle E_{max} = f_{ts,t} \cdot e_{w,t} \cdot f_o}
Evaporation unsaturated:
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle E_{u} = \begin{cases} 0.0 & \text{if } d_{gw,t} \text{ is } \leq 0.0 \\ min(E_{max}, h_u \cdot \frac{d_{r,1}}{d_{gw,t}}) & \text{otherwise} \\ \end{cases} }
Potential evaporation saturated:
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle d_{s} = w_{g,t} - ( B_{c} - d_{b,c} )}
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle d_{r} = max( 0.0 , w_{g,t} - ( B_{c} - d_{r,1} ))}
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle E_{p,s} = (E_{max} - E_{u}) \cdot f_s}
Evaporation saturated zone:
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle E_{s} = max (0.0 , min ( E_{p,s}, d_{s}\cdot f_{ws}, d_r \cdot f_{ws}) ) }
Evaporation total is the sum of evaporation in the saturated and unsaturated zone:
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle E_g = E_u + E_s}
where
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle B_{c}} = the datum height of the surface of cell c, set by the elevation or a Terrain elevation prequel.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle w_{g,t}} = the ground water level (datum height) at time t.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle d_{gw,t}} = the depth of the ground water level, which is equal to the column height of the unsaturated zone at time t.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle f_{ts,c}} = the transpiration factor at current season c, of the buildings (plants) on the surface, or the surface terrain's transpiration factor if none present.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle f_{ts,n}} = the transpiration factor at coming season n, of the buildings (plants) on the surface, or the surface terrain's transpiration factor if none present.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle f_{se,t}} = Season fraction. Used for interpolating the transpiration factor.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle f_{ts,t}} = Can be supplied as four values; it is an interpolated value based on the current and next season.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle e_{w,t}} = the evaporation rate of the weather at time t
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle f_o} = the calculated feddes oxygen stress factor, calculated using the 3rd and 4th root depths and the feddes trapezium interpolation model and the ground water depth.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle f_s} = the calculated feddes saturated zone root update factor, calculated using the 1st and 2nd root depths and the feddes trapezium interpolation model and the ground water depth.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle d_{b,c}} = The ground bottom distance of the cell c, defined by a Bottom distance prequel or a general GROUND_BOTTOM_DISTANCE_M of the Water Overlay.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle d_{s}} = the column height of the saturated zone covered by the roots
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle d_{r,n}} = the nth root depth value.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle h_u} = the amount of water in the unsaturated zone.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle E_{max}} = the potential max evaporation
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle E_{u}} = the evaporation in the unsaturated zone
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle E_{p,s}} = the potential evaporation in the saturated zone
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle f_{ws}} = The WATER_STORAGE_PERCENTAGE of the ground terrain type, used here as a fraction.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle E_{s}} = the evaporation in the saturated zone
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle E_{g}} = the total evaporation from the ground.
Related
Groundwater level formula (Water Overlay)
Models
Ground model (Water Overlay)
Evaporation model (Water Overlay)
