Ground bottom flow formula (Water Overlay)
Revision as of 12:59, 27 February 2024 by Frank@tygron.nl (talk | contribs)
Ground water flowing in from deeper ground layers through the bottom boundary, due to head pressure from water bodies situated outside the project area is calculated per grid cell. The formula is based on the principles used in the formula of Pankow for estimating this ground bottom flow[1].
The water level change due to ground bottom flow is calculated using the following formula:
Δwlc=hd(t)hccc,tfΔt246060
The external bottom head pressure is variable over time by the introduction of hv(t):
hd(t)=pc,tf+hv(t)
Finally, the actual amount of water flowing into the ground from the deeper ground layers through the bottom boundary is calculated as followed:
Δsc=Δwlcwsc
Δwlc = The water level change due to the ground bottom flow at cell c, in meters.
hc = Ground water head at cell c.
hd(t) = Additional global pressure at time t, in meters
pc,tf = Ground water level (or head pressure) in meters at timeframe tf.
hv(t) = Additional variation of bottom head pressure over time
cc,tf = Resistance of the bottom boundary in days at timeframe tf
wsc = Water storage fraction of the soil
Δsc = Water flowed in through the bottom boundary from deeper ground layers, in m
  • The calculated Δwlc is essentially the change in groundwater level, inherently taking into account the porosity of the soil. The final Δsc is representative of the actual amount of water, i.e. the height of the water, if the relevant quantity of water wasn't in the ground but sat on the surface instead.
  • pc,tf and cc,tf can both be provided as spatially variable values using prequel overlays. These prequels can have multiple timeframes, as indicated by the formula, allowing changing head and resistances over time.
  • hv(t) can be provided as a set of values, variable over time.
  • A head pressure lower than the water level in the project is also allowed, resulting in ground water lowering and flowing into the deeper ground layers and out of the project area.
Groundwater level formula (Water Overlay)
Models
Ground model (Water Overlay)
  1. Estimating ground bottom flow, http://grondwaterformules.nl/index.php/formules/ontwatering/kwel-berekenen-pankow, last visited on 2-9-2020
