Pump angle (Water Overlay)
Revision as of 12:47, 29 January 2024 by Frank@tygron.nl (talk | contribs)
Icon | Key | Unit | Range | Description | Default value |
PUMP_ANGLE | geo angle (0-360°) | The top down orientation angle of the pump. | 0 |
Adjustable in the pump step of a Water Overlay wizard
- This angle is used to generate a line for the front and end points of the pump. Additionally, the elevation is also automatically adjusted for the region perpendicular to the pump angle.
- If no angle is available as an attribute, the angle can be calculated by using the Generate Angles option in the Pumps step of the wizard.
