Pump angle (Water Overlay)
Revision as of 09:31, 29 January 2024 by Frank@tygron.nl (talk | contribs)
The principle for a weir with an angle. The same principle is applied for a pump.
  • This angle is used to generate a line for the front and end points of the pump. Additionally, the elevation is also automatically adjusted for the region perpendicular to the pump angle.
  • If no angle is available as an attribute, the angle can be calculated by using the Generate Angles option in the Pumps step of the wizard.
