Ground transpiration formula (Water Overlay)
For all underground evaporation calculation, the ground water depth at time t is used.
dgw,t=Bc−wg,t
Feddes oxygen stress factor:
fo={1.0if dgw,t is ≥dr,3dgw,t−dr,4dr,3−dr,4if dgw,t is ≥dr,40.0otherwise
Feddes saturated zone root update factor:
fs={0.0if dgw,t is ≥dr,11.0−dgw,t−dr,2dr,1−dr,2if dgw,t is ≥dr,21.0otherwise
Max potential evaporation:
Emax=ft⋅ew,t⋅fo
Evaporation unsaturated:
Eu={0.0if dgw,t is ≤0.0min(Emax,hu⋅dr,1dgw,t)otherwise
Potential evaporation saturated:
ds=wg,t−(Bc−db,c)
dr=max(0.0,wg,t−(Bc−dr,1))
Ep,s=(Emax−Eu)⋅fs
Evaporation saturated zone:
Es=max(0.0,min(Ep,s,ds⋅fws,dr⋅fws))
Evaporation total is the sum of evaporation in the saturated and unsaturated zone:
Eg=Eu+Es
where
Bc = the datum height of the surface of cell c, set by the elevation or a Terrain elevation prequel.
wg,t = the ground water level (datum height) at time t.
dgw,t = the depth of the ground water level, which is equal to the column height of the unsaturated zone at time t.
ft = the transpiration factor of the buildings (plants) on the surface, or the surface terrain's transpiration factor if none present.
ew,t = the evaporation rate of the weather at time t
fo = the calculated feddes oxygen stress factor, calculated using the 3rd and 4th root depths and the feddes trapezium interpolation model and the ground water depth.
fs = the calculated feddes saturated zone root update factor, calculated using the 1st and 2nd root depths and the feddes trapezium interpolation model and the ground water depth.
db,c = The ground bottom distance of the cell c, defined by a Bottom distance prequel or a general GROUND_BOTTOM_DISTANCE_M of the Water Overlay.
ds = the column height of the saturated zone covered by the roots
dr,n = the nth root depth value.
hu = the amount of water in the unsaturated zone.
Emax = the potential max evaporation
Eu = the evaporation in the unsaturated zone
Ep,s = the potential evaporation in the saturated zone
fws = The WATER_STORAGE_PERCENTAGE of the underground terrain type, used here as a fraction.
Es = the evaporation in the saturated zone
Eg = the total evaporation from the underground.
Groundwater level formula
Models
Underground model
Evaporation model
