Pump area (Water Overlay)
Revision as of 13:14, 21 April 2023 by Frank@tygron.nl (talk | contribs)
PUMP_AREA | boolean | When true the Pump is spread across the entire building surface. | 0 |
A pump consisting of one line area, with one entry point for the lower and one for the upper Water level areas. It only used a single cell to subtract water from, which might not be enough.
A pump consisting of two separate areas, one for the lower and one for the upper Water level areas. It uses a lower level threshold and requires multiple grid cells to subtract enough water. It is configured as a PUMP_AREA.
- Selecting this option is useful when the PUMP_Q value is too large for a single cell.
