Weir target level (Water Overlay)
Revision as of 16:00, 12 January 2023 by Frank@tygron.nl (talk | contribs)
  • The interval before re-evaluating the Weir height is configured using the Water Overlay's model attribute Weir move interval s.
  • This value is set as a single value, not an array.
  • The weir can move with a distance defined in the overlay with the model attribute WEIR_MOVE_STEP_M.
  • The weir's movement range can be set using the overlay's model attribute WEIR_MOVE_RANGE_M. This can be interpreted as the maximum allowed difference in the default WEIR_HEIGHT and the adjusted weir height.
