Weir angle (Water Overlay)
The weir angle is used to convert a weir loaded in as point-based data to a line which is used in the simulation to define from where to where the water should flow across the weir. It also automatically adjusts the elevation perpendicular to the direction of the weir, so that water can only flow from one side of the weir to the other through the weir, rather than around it.
  • The width of the generated dam is equal to the weir's WEIR_WIDTH, multiplied by the WEIR_DAM_MULTIPLIER of the Water Overlay.
  • If a weir angle is available for a weir which is already line-shaped, the weir is first interpreted as a point, and then the direction and elevation are adjusted accordingly. The centre of the weir's polygon is used.
  • If no angle is available as an attribute, the angle weir angles are automatically oriented based on the water level areas. If there are no water level areas in a project, an error is displayed.
The error is shown when the weir is only in one water level area. .
