Evaporation model (Water Overlay)
Water can evaporate from the hydrological model over time. Multiple forms of evaporation are implemented, namely surface and underground evaporation.
Both forms of evaporation can be configured directly by setting the weather's evaporation rate. The weather's evaporation rate is defined as a period during which a certain rate of evaporation will take place, similar to rainfall. Multiple periods of evaporation can be defined, and at any specific moment during the simulation an exact evaporation rate is defined by the weather.
The evaporation is interpreted as an evaporation amount per second. In case less water is present at set location, the maximum possible evaporation will not be higher than that amount. The remainder will not be carried over to the next time step. Excess evaporation potential from a previous timestep is therefore always discarded.
The default setup for evaporation consists of a single period of evaporation. It is possible to configure an evaporation rate which varies over time. More periods with varying amounts of evaporation (including an evaporation rate of zero) can be defined.
Surface evaporation
Water situated on the surface is conceptually able to evaporate. The amount is based on the weather's evaporation rate and the overlay's SURFACE_WATER_EVAPORATION_FACTOR. The product of these two attributes results in the actual rate of evaporation. The water in each individual cell at the surface is then subject to the calculated rate of evaporation.
Underground evaporation
Water can evaporate from the underground if the cell's surface meets either of the following criteria:
In other words: if a construction is present the construction's properties are used, otherwise the terrain's properties are used.
Conceptually, water can evaporate from the underground via crops and foliage. These can draw water from the unsaturated and saturated zones in the underground, if their roots reach deep enough and the terrain or construction have a positive evaporation factor. Water is drawn from the underground and evaporated into the air, effectively removing it from the hydrological model. Water for evaporation can only be drawn from sections of the underground which are within reach of the roots, as defined by the root depth. Using the multiple root depth values, it is also possible to define a threshold at which the roots are unable, or less able, to extract ground water, due to oxygen stress. It such case up to 4 root depth values have to be provided, from deepest to less deep.
The underground evaporation can be configured directly by changing the terrain type's WATER_EVAPORATION_FACTOR and construction 's WATER_EVAPORATION_FACTOR. If these attributes are set to 0, no underground evaporation will take place.
Similar to the surface evaporation, the rate of underground evaporation is also determined by the weather definition's evaporation rate. Multiplying the weather's evaporation rate and the evaporation factor of the construction or terrain (as applicable) gives the actual evaporation rate for the underground.
Underground evaporation first draws water from the saturated region and then from the unsaturated region. If, according to the calculated evaporation rate, a sufficient amount of water can evaporate from the saturated zone, no water will evaporate from the unsaturated zone. Otherwise, all water in the saturated zone which is in reach of the roots of the construction or terrain (as applicable) is evaporated, and the remainder of the amount of water which should evaporate according to the evaporation rate is evaporated from the unsaturated zone. The sum of evaporation in the saturated zone and the unsaturated zone will never exceed the calculated evaporation rate.
Example for dynamic evaporation
35 1,5
42 1,9
120 0,5
  • The first period is starts at t=0 minutes and ends at t=35 minutes. In this first period, water will evaporate at a rate of 1,5 mm per day. Uniformly this gives 1,5 / (24 * 60 * 60) = 0.000017 mm per second.
  • The second period starts at t=35 minutes and ends at t=42 minutes. In this period, water will evaporate at a rate of 19 mm per day. Uniformly this is 1,9 / (24 * 60 * 60) = 0.000022 mm per second.
  • The last period starts at t=42 minutes and ends at t=120 minutes. In this period, water will evaporate at a rate of 5 mm per day. Uniformly this is 0,5 / (24 * 60 * 60) = 0,000006 mm per second.
  • Underground evaporation will only take place when the underground model is active.
Related formulas
Related models
