Drainage (Water Overlay)
Revision as of 12:30, 4 December 2020 by Frank@tygron.nl (talk | contribs) (Created page with "Drainages provide connections between the underground and nearby waterways, draining groundwater to levels which are optimal for agriculture. Drainage can be passive, where wa...")
Drainages provide connections between the underground and nearby waterways, draining groundwater to levels which are optimal for agriculture. Drainage can be passive, where water drains based on water head differences, or active, where the water is pumped from the drain to the nearby waterway.
A drainage is a area-based construction.
