Inlet (Water Overlay)
Revision as of 12:47, 2 October 2020 by Rudolf@tygron.nl (talk | contribs)
Lower threshold is a key of the Water Overlay that is used for both Pumps as Inlets and Outlets.
Upper threshold is a key of the Water Overlay that is used for Pumps, Inlets, and Outlets.
  • Each Inlet attribute functions as a limit to the flow. If multiple are defined, the flow is limited by the strongest limit. If neither an INLET_Q or any threshold is defined, there will be no flow.
  • A negative INLET_Q changes the Inlet to an Outlet.
  • The lower and upper thresholds can be seen as a the lowest and highest of "range" of valid water levels. If the actual water level does not fall in the specified range, the inlet will allow water to flow in or out (depending on the configuration) to correct the water level.
