Pump lower threshold (Water Overlay)
Revision as of 07:06, 15 May 2020 by Rudolf@tygron.nl (talk | contribs)
Template:Overlay attribute This attribute can be defined as values over time, using an array of values defining interpolation-time. This allows users to more dynamically define the target water level this pump maintains.
- When the PUMP_Q of the pump is positive, the pump will not pump if the water level is lower than or equal to the lower threshold. If the PUMP_Q is negative, the pump will not pump if the water level is higher than or equal to the lower threshold.
